half-9
Sorry I did search - honest!
OK - First apologies its an old topic. And I am really killing this one, sorry. I have searched on the forum, but can't find a solution...
I have been calculating (on a spreadsheet) different wheel widths and the impact on the width of spacer needed to fit them (I intend to modify the arches).
I started with what I think are the original fitments 6.5J x 15, et 33
I have assumed that 6.5j = 6.5 inches - Is this right??
Anyway - by my calculations 6.5J/inches converts to overall rim width of 165.1mm which when divided by 2 gives 82.55mm plus the offset +33 (mm?) equates to a rear rim width of 115.55mm. SO the distance from the wheel mounting face to the rear most edge of the original rim is 115.55mm.
The logic I am applying here is that as long as I maintain approx the same distance between mounting face & rear rim edge, then I can get a alloy wheel as wide as I like but will then need serious arch mods to house it. (I hope your following me coz this is driving me nuts!)
I then calculated for a variety of width & et combinations.
E.g. I read Blue_Joe has 7.5j x 17 rims et 52 plus 25mm spacers
SO 7.5J = 190.5mm, centreline is therefore 95.25mm plus wheel offset of +52 = 147.25mm as the distance from mounting face to rear rim edge. Hence he needed 25mm spacers which then reduced that distance to 122.25mm which is comparable to the original 115.55mm ( so clearance behind the alloy must have deteriorated by only 6.7mm)
Great!! - but I think my theory is flawed as original 6.5J wheels were dressed in 195/50/15 tyres - which implies that the rim miust be at least 195mm wide not 165mm as per my theory above.
I am confused by this. Can anyone shed anylight on this? Also how do I post my spreadsheet calcs on the forum so that someone can put me out of my misery.
ANY help other than recommending a psychiatrist would be much appreciated.
