mattkh
Barrel
Apart from drilling the hole into the barrel as per Bentley (exact location is crucial), it's quite easey. Done this on Supercharged's lock barrel some time ago, and once we had the hole in and poked a sharp object in there, the barrel just fell out. The barrel is just held in place with some spring-loaded mechanism, which to access you need to drill this hole and then press it using a sharp object inserted into said hole.
Tempest
