NickVR6 0 Posted November 26, 2006 I have trauled through all the post on the search but im still getting nowhere trying to fit the audi gauge panel. If anyone can help with any of the following id be very grateful! How do you get the centre consule out? Do you use both the cut down audi plastic cover which i have managed so far, and the metal plate or just the front plastic? In the centre consule theres a screw in the way top left, loathed to hack all that out because surely that holds the centre consule in? How do you secure any of it to the car! You have to remove the side brackets on the audi metal bit because theyd never bend in far enough without ruining it, so cant use those because ive cut em off. BTW i have the vag lower gauges too, but im sure this should all still fit?? Keen to get it finished as half the wiring is out of the car trying to sort all the aquamist and these darn gauges and i want to make it to stealth! Ive got venoms nice three gauge holder but that definately wont go in so im back to audi set up or use the venom one up top and relocate the stereo, which is looking more temting by the second!! might just throw it in the glove box bth Anyone been through all this and made it work! :oops: :( i know im being a nonse Quote Share this post Link to post Share on other sites
NickVR6 0 Posted November 26, 2006 lots on early style dash which looks easier! Quote Share this post Link to post Share on other sites
Lippy 0 Posted November 27, 2006 nick - are you struggling to get the pastic bit off the metal er... bit which the gauges are stuck in? If so, brute force, they just pull out IIRC, no cutting or anything. This had me stumped as I didnt want to break anything. I assume you don't need to know how to pull out the centre console in your C - sure u've done that before. Quote Share this post Link to post Share on other sites
Steve16v 0 Posted November 28, 2006 Did you have a look at this http://the-corrado.net/.archive/forum/viewtopic. ... sc&start=0 I held the gauges in using 2 brackets as ye can see in the pic When refitting I didn't use the screw points underneath the heater controlls as they are not needed Quote Share this post Link to post Share on other sites
Lippy 0 Posted November 28, 2006 nice work that man Quote Share this post Link to post Share on other sites
Steve16v 0 Posted December 1, 2006 And here is a (very bad) pic of them lit up in the dash Quote Share this post Link to post Share on other sites
dnac 0 Posted December 2, 2006 They look well cool, what gauge holder is it? or did you make your own from scratch? I was either considering buying the two gage one that sells on ebay for 22 quid and goes in the lower cubby hole thing, or trying to get a piece of flat carbon fiber and making my own. Quote Share this post Link to post Share on other sites
Steve16v 0 Posted December 3, 2006 They are a set of audi 80 gauges in their orignal panel that has been cut and shaped to fit in the corrado centre console Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 3, 2006 nicely done.... Quote Share this post Link to post Share on other sites
