jslootweg 0 Posted November 27, 2006 I'm trying to fit my upgraded loom. Everyone says its so easy, but i can't find the information i require. Which side does the switch wire from the dash come from on a corrado, i.e. which side connects up to terminal 86? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted November 27, 2006 mine used two relays but either way you can work it out from the diagram :wink: Quote Share this post Link to post Share on other sites
jslootweg 0 Posted November 27, 2006 Ok cheers for the diagram, but which side is the headlight which the relay connection 86 is made? Quote Share this post Link to post Share on other sites
lesarcsneil 0 Posted November 27, 2006 You could use either but the lengths of wires on a loom normally mean you'd use the nearside (on the same side as the battery). Also worth doing a search on 'headlight loom' on the forum to find out how to disable the dim-dip. I fitted a loom yesterday and it's made a huge difference. neil 94 Flash Red 16v Quote Share this post Link to post Share on other sites
