johnxl1s
KEY FOBS
We have a Reno Clio 2001/old model /import I think, one of the key fobs will unlock/lock ok but will not start the car, the other key/fob/remote starts the car ok but will not lock the car.
I also have a 2000 VW Golf TDI with one key fob not working on the alarm but will start ok, not much use as the car needs unalarmed
where does these does anyone know
on the golf is the small red light flashing on the key when you press the button/ have you tryed changing the battery in the remote? and do you have the plastic service key or a spare key?
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave key in the ignition.open window just incase
2. Mechanically lock the vehicle using the Drivers door using a second key
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
Note: When performing programming on additional remotes the procedure is exactly the same, except you press the unlock button 2, 3 or 4 times for different remote.
For example: If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
Remote Control Erasing (1997 ON)
Procedure
1. Switch ignition ON and leave key in the ignition.open window just incase
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Press the remote control unlock button 5 times in 1-second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch ignition OFF, all remotes are now tuned in..
