GAZ-G60 0 Posted October 13, 2003 Hi all, I am the proud owner of a 1992 Corrado G60 in Flash Red FVWSH with 56,000 miles on clock. Completely standard car. Problem: My rear spoiler appears to have jammed, I searched the forum and discovered how to manually lower it and this has now been done. However spoiler will neither work automatically or manually with switch. The ABS light now glows continuosly and becomes brighter when the spoiler switch is pressed ?? also there is a buzzing coming from the vacinity of the dash when the switch is pressed :?: Does the above ring a bell with anyone? during my search of the Forum I remeber reading that the spoiler and dash board gauges use the same fuse ? all gauges working fine so I assume it's not a fuse? Any help would be much appreciated. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 13, 2003 The spoiler uses different fuses depending on the car and its year, Just check them all but from the buzzing sound it sounds like a relay needs replacing Quote Share this post Link to post Share on other sites
GAZ-G60 0 Posted October 14, 2003 Got the spoiler working last night with the help of a friend, Turned out to be a lose wire and dodgy relay. Thanks Supercharged. Quote Share this post Link to post Share on other sites
