JMC 0 Posted December 14, 2006 New toys have arrived from Audioscape - 8 sheets of Skinz sound deadener, some of the prep spray for the metal work, Rhino Skinz door kit (to replace the moisture barrier), moisture guard to go behind the speaker (acoustically transparent moiture barrier), and the wave diffuser to go on the outside skin of the door behind the speaker. Thought it was about time I did the doors as I've already done the boot, rear quarters, under the rear seat, some of the floor and firewall. Looks like it could be a fun Christmas after all :D :D Quote Share this post Link to post Share on other sites
Corradokid135 0 Posted December 14, 2006 very nice, good luck on the install ;)[list=]very nicer, good luck on the install ;) Quote Share this post Link to post Share on other sites
JMC 0 Posted December 14, 2006 very nice, good luck on the install ;) Thanks Corradokid135, been putting off doing the doors given the level of hassle involved in prepping and using the sound deadening on the outside skin of he door. But I feel it is now time to do it properly.... Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 14, 2006 This product made a huge differance to our project golf Jonathan. Its a great product Quote Share this post Link to post Share on other sites
JMC 0 Posted December 15, 2006 This product made a huge differance to our project golf Jonathan. Its a great product Cool, look forward to getting it all done Darren. Just wish I had a nice warm garage to work in now..... Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted December 15, 2006 I would be interested in the rhino skinz stuff as the OEM stuff never goes back on correctly. I would be interested to see how well it works! Good stuff. I am jealous 8) Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 15, 2006 done the boot, rear quarters, under the rear seat , the doors make the biggest difference imo sound deadened the inner skin and the outer nearest the door card and then put neoprene on the inner and rain stop guards at the rear of the speakers ..all from jim at audioscape Quote Share this post Link to post Share on other sites
JMC 0 Posted December 15, 2006 done the boot, rear quarters, under the rear seat , the doors make the biggest difference imo sound deadened the inner skin and the outer nearest the door card and then put neoprene on the inner and rain stop guards at the rear of the speakers ..all from jim at audioscape Just out of interest how much of a pain is it to put the sound deadening on the outer skin of the door (i.e. reaching through the holes on the inner skin) - I get the feeling it is not easy to get at, especially with all the electric window gubbins..... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 15, 2006 its not as bad as you would think but its a knuckle scaper :-) i heated my sound deadening with a paint stripper gun so it stuck on contact and then flattened it with a small roller, the type you use on wallpaper joins, its easier buliding smaller pieces into a jigsaw effect due to the small gap in the door but you getting a satisfying "clunk" from the door when your done ..sounds quality ! this was when i'd done most the inside .. Quote Share this post Link to post Share on other sites
JMC 0 Posted December 15, 2006 Cheers Gixxeruk, got the feeling it would be a bit of a scraper. Might be a good time to invest in a heat gun as well - especially trying to do it at this time of year. Looking forward to the solid "clunk" on closing the doors.... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 15, 2006 JMC, i bought a heat gun for the job mate , think it was £8 from b&q .. bargain , just sticks better and makes it more flexible Quote Share this post Link to post Share on other sites
JMC 0 Posted December 16, 2006 Had a fun afternoon working on this. Stripped the door, removed the old moisture barrier, actually removed the factory sound deadening sheet from the door, as there were more air pockets behind it than there were bits attached. So after copious cleaning of the metalwork (and cuts and scrapes to knuckles and hands) the Skinz went in on the outer panel, followd by the Wave Diffuser sheet behind the speaker and a load of neoprene over the rest of the Skinz. Then I tried using the Rhino Skinz where the moisture barrier should go. Nasty, nasty stuff. Maybe it wasn't warm enough when I used it, but it cracked and split, and did it's best to ruin my afternoon. Anyway, eventually got it done and everything sounds very nice now. The door gives a good "thunk" on closing and the speaker sounds good. All I need now is another spare day to do the other door :roll: Quote Share this post Link to post Share on other sites
