Bups
Heater not working properly?!
What could cause the heater not to work on speed 1 and 2 but works fine on 3 and 4?! Also the light doesnt glow up on the heater panel when you swith the side lights on... Any ideas what could cause this?? :? Oh and its the later type C with the twisty knobs...
I think the optics are pretty poop so maybe the light could be broken. Pull it out and have a look.
As for the fan not working, not sure, wouldnt be the thermal fuse gone? Try taking the knob off and cleanign the conenections.
Hope you get it sorted
as Son of a Beesting, it could be the bulb or poor connection , the fan will either be the thermal fuse ( a new resistor needed which cost pence from maplin) or the copper contacts behind the switch are dirty - pull the knob off and clean the contacts and make sure they do contact sometimes it needs a bit of manipulation
  VR6 said:
As usual, the search would help .....
Iv used the search and tried to clean the connectors, pull the knob off to chek the bulb and everything seems fine.. :? Think il try and change the resistor and see if that brings the heater to work properly.. Dont know what to do about the light part.
  GIXXERUK said:
did you check the voltage at the bulb ?
did you pull the knob off the speed setting ?
what did you clean it with ?
Yes i checked the power at the plug behind the dash that connects to the heater controls, power there is ok but the light doesnt glow up..:? I pulled the knob off and cleaned around the area with a dry cloth then tested the speeds but still no joy...
Ok this is reall pi**ing me off now!!! Ive managed to get the light going on the control panel but cannot get the heater to work on speed 1 & 2, it still works fine on speed 3 & 4, ive cleaned the connectors/changed the resistor on the motor and even tried about three different heater control panels bit its still the same.. Any ideas anyone? :?
It will be the resistor that is knackered. There a 'how to' on here somewhere. Its an easy job, I have it to do as well, although I'm waiting until nicer weather... just in case I am with out a fan for a few days (just in case I break it) ;)
- Ross
rosswalker,
  Quote
- Ross
Iv changed that too... :? I think the later models are different to the early one's thoh. I think it may just be the motor, still not sure thoh...
I doubt its the motor, if it was it wouldn't work at any speed.
Rosswalker it's a 10min job to replace the thermal fuse and it can all be done indoors. You couldn't possible go wrong :wink:
Iv changed the "thermal fuse" by looking at the guide on this forum but its still the same..
mines(94 vr)doing the same thing......last weekend i popped out the heater fascia and control nobs to change the single centre nob 1.2v 286 capless bulb - and after putting it all back on, only 4th speed would work....
....sunday i took apart again and noticed that if i apply pressure differently when turning nob, and with the front fascia off, i could get it to work on 1,3 +4!? put it all back together and now have speeds 3 + 4 :roll: seems to be the connection somewhere - more fiddling next weekend i reckon.....
  Quote
pull the fan speed knob off and clean it with a light grade emery (copper strip) and check the inside of the knob , clean with emery and make sure its contacting , its only sprung metal, pull it out a touch
