Supercharged
Pads and Part Numbers for Audi S2 / Girling 60 Calipers
I need some pads for some S2 Calipers I have coming to me, I have standard VAG 280mm discs so would like Pagid FR pads if pos...
I went to German Jewish and Mongolian today to try and aquire some...
I asked for the above but the first set were clearly wrong (- way too small) I had the Audi part number of 895 698 151 but this did not cross reference...
They did have 447 698 151A and these looked like they could be them, I bought these and when you stick that number into ETKA it shows a twin pot caliper but it is a seperate part number to whats above (doesn't supercede)
Does anyone know if what I've got is correct?? - I've highlighted the GSF part number below but I have a feeling I need the more expensive pads down the list...
Well, I've tried the pads in the carrier but there is a strange metal clip on one pad that doesn't want to fit in place so I reckon they are wrong - forgot to mention they also have the wear sensors attached to the other pad - do the S2's all come with these?
Yep, cheers mate - they look good and i've removed the hoses...
I really need a site that lists Pagid part numbers but can't find one...
This site any use? If you have a look at the fundamentals section on there the part number you have doesn't match up to the ones listed.
64580 is the correct GSF part number for the S2 though.
