Rado k
RH AG Cup wheels
After looking around i've found that i love the RH AG cup wheels.
Was thinking of getting 8x17 et 32 from here:
http://www.dubmeister.co.uk
Will these fit ok and do you think they would look good on a white Corrado???
Or maybe would 9x17 et 30 fit on the rear with the above fronts??
Many Thanks
Kevin
Im not sure whther youd need arch mods ( ithink you wouldnt) but yes they are nice.
If youre car was nice and low with these bad boys on then it would look quality.
Might be worth asking if someone can you do you a photochop of them so you can get an idea...
Great choice, just need to shave a touch off front calliper to fit otherwise no issues
Even with the 9's on the rear??? What about using 3mm spacers?
Just need to see what size tyre to go for now. Any ideas?
Not sure about the 9s, heres how a similar RH wheel looks on a light coloured car
they dont look like 5x100s to me unfortunately, i think the transporters are different. the bolt holes actually look more spaced in the picies too :-(
After all this like the weather i've changed my mind and i'm going for the Platin P16 in 8x17 et35 as long as they clear the calipers ok!!
They look excactly the same as the RH AD Cup wheel which is a smoother looking wheel.
Kevin
Oh yeah i see it now.
This is a pain in the arse trying to get the right wheels for the colour and shape of the car. The AG's don't look as good as the proper split rims so i guess it's the Platin P16's or save for the ZW5's.
Haven't even picked up the car yet!! Roll on Saturday.
