oxfordpaul 0 Posted January 15, 2007 Hi all, my roof aerial base has rotten but VW only sell the complete unit. Does anyone know of a replacement base that would be suitable? Also does the original aerial wire detach at the base of the amplifier or does the entire lead need to be routed through the car if I bought a new one? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 Do you just need the gasket? - I think VAGParts so a repair kit... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 ...and the lead just plugs in underneath headlining Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted January 15, 2007 So how many hours labour do you think I should be charged? And yes, i just need the gasket (plastic bit round the base) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 look in the aladins cave section on there website... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 15, 2007 easy fix, pull the plastic trim at the rear of the roof once you've climbed in the boot, pull the headling down a little unplug the ariel and booster cable undo the (17mm or 19mm cant remember) nut and the ariel is out i wouldnt pay to have that done tbh Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted January 15, 2007 I was quoted 2 hrs labour for this at £28 per hour by a bodyshop!!! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 15, 2007 its 15 mins if you have a brew aswell :-) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 oxfordpaul, if you drive down to Woodbridge I'll do it for £27.50 (plus vat of course) :smile: Yeah - deffo one to do yourself, especially as it involves interior stuff - need adjustable spanniel, some polish to clean the roof, maybe some insulation tape... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 15, 2007 oxfordpaul, if you drive down to Woodbridge I'll do it for £27.50 (plus vat of course) Supercharged, you just keep on giving , you good samaritan :-) Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted January 15, 2007 Cheers for the help guys, I've also found the repair kit on VAg parts - £10.95 instead of £60 plus at the stealers. Quote Share this post Link to post Share on other sites
