will 2 0 Posted January 18, 2007 in my car the rear seat does not have the raised center section, is it possible to just take mine out and fit one in that has the raised center or has there any brackets etc got to be fitted if so has anyone got some photos of the fittings needed thanks Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 29, 2007 it could be there on yours , where the centre console meets the rear seat is where the armrest bolts to , there should be four holes for it to bolt to, if they are there they would be under your seat Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 29, 2007 roughly where the black circle is, is where the armrest bolts to Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 29, 2007 http://the-corrado.net/.archive/forum/viewtopic. ... at+armrest sounds like you have to bolt or weld a bracket in Quote Share this post Link to post Share on other sites
khurrado 0 Posted January 29, 2007 If its a 2.0 litre like mine, they came with flat benches, and did not have arm rests. The part of the car that the arm rest would bolt onto is just behind the rear ashtray, where i put my change. You would have to take it out and drill 4 holes into the plastic to bolt down the arm rest. Quote Share this post Link to post Share on other sites
will 2 0 Posted January 29, 2007 cheers lads for the info, by the way there just happens to be a rear console on ebay now with the holes in ready for fitting. shame i dont have the rear seat yet 8) Quote Share this post Link to post Share on other sites
