corozin 0 Posted January 26, 2007 Not necessarily - if you loosen off the engine subframe and get some decent leverage onto it you can pry it apart far enough to get the bolt in. Heresites: It's a pretty involved job, and needs two people for some parts of it. I engaged a mobile mechanic to help do mine (bear in mind I replaced a lot more than just the wishbones) and it was still a fair bit of work to get done. If you haven't got one already, I suggest you get a Bentley manual rather than ask for a step by step guide. You should look at a few diagrams before you get stuck in. It's about 2-3 hours work each side to do, so plan ahead Quote Share this post Link to post Share on other sites
herisites 0 Posted January 26, 2007 corozin said: Not necessarily - if you loosen off the engine subframe and get some decent leverage onto it you can pry it apart far enough to get the bolt in. Heresites: It's a pretty involved job, and needs two people for some parts of it. I engaged a mobile mechanic to help do mine (bear in mind I replaced a lot more than just the wishbones) and it was still a fair bit of work to get done. If you haven't got one already, I suggest you get a Bentley manual rather than ask for a step by step guide. You should look at a few diagrams before you get stuck in. It's about 2-3 hours work each side to do, so plan ahead Ouch sounds like its going to be a bit harder to do than my fiesta was :lol: well i will have to get someone to give me a hand as it sounds like a cnut. Quote Share this post Link to post Share on other sites
