hayes100
staring problems
hi people well my vr6 has a slight missfire which i don't seem to be able to fix but it is starting really badly it always has done it turns over well (as far as i can tell) but it splutters alot befor firing up it does start it turns over for about 10 seconds. i have had the coil pack done spark plugs done and ht leads and the fuel pump done and temp sender to try and fix it but doesn't seem to have done anything anyone else had this problem any welp is great
Tim
If you disconnect the plug to the MAF does it behave the same way?
Also have you cleaned out the ISV? as it may be stuck shut.
What year is it i.e is it OBD1 or OBD2?
i will try removing the cable to the maf and see if that works and no i havent tried the isv im not very knolagable on cars i wouldn't know were to find it its a 1994 i think its the obd1
Usually on OBD1 cars, it should splutter and die when the MAF is unplugged.
Sounds like it could well be the MAF. Definately worth checking the ISV too.
Whereabouts are you? I've got a spare MAF you could try.
im in somerset near taunton
if you have got one thats great it did nothing started up like usuall when i started it with the cable off
