skinnyman9000 0 Posted January 26, 2007 Oh dear: Nearside rear seat belt not working Nearside headlamp producing incorrect image Nearside rear brake binding Both rear brake hoses excessively corroded Brake load sensing value linkage seized Exhaust emits dnese blue smoke at idle Parking brake efficiency below requirements Nearside rear parking brake recording little effect Oh bugger! Altho on closer inspection its basically a new headlamp bulb, seatbelt and rear brake overhaul. Oh, and the blue smoke is likely to be caused by the value seals being worn. Fun times!!! Quote Share this post Link to post Share on other sites
khurrado 0 Posted January 26, 2007 Well atleast you know that there is something wrong. Better that than not to know. Quote Share this post Link to post Share on other sites
skinnyman9000 0 Posted January 26, 2007 True, i was hoping it would sail through too, hahaha! Although the rear brakes binding might explain why it doesn't feel too sharp off the line, and the less than impressive mpg. I actually look forward to MOT day because generally my cars feel sooooo much better once these things are sorted Quote Share this post Link to post Share on other sites
