steve @
8x17 offset help.
Just to run this past u guys. . . .
8x17 35ET (5x112) with the thinnest adapters I can find ,20mm, brings to 15Et right? is this possible on a Vr lowered 35mm ( i am thinking not)? couldn't really find much on adapters are 5x100 to 5x112 15mm available i.e to get a 20ET? Whats the lowest ET you can run on a VR without rolling the arches? any info would help. Cheers
Et 30 is probably the absolute limit on 8x17 without arch work and even that will need work if you go v. low. ET 35 on 8s is safer
