latestarter2
vibration
Odd one...when ive got passnegers in the car I need a vibration from the back end..(not mine I hasten to add!!) sounds like the exhaust is knocking but when I took it the local garage to have a look they said it was all clear right the way through?
It vibrates when i accelerate hard?
Its an afetrmarket s/s unit.
is the exhaust catching the rear suspension arm where it goes over as this would raise up with passengers in the rear?
Aftermarket exhausts often sit on or very near, the rear axle, and will vibrate against it when accelerating or if you've got extra weight in the car.
I cured it on my last car by cable tying some rubber rad hose (cut in half) on the axle. Worked a treat ;)
