steveo29 0 Posted October 19, 2003 beavis tells me my 5k flat spot could be related to a dodgy hall sender,before i order a new un can anyone give more info?...i cant afford to buy something i dont need while im here..wheres the best/cheepest place to buy??and should look for a hall sender or new dist thanks :wink: Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 19, 2003 i'll move this into problems :wink: Quote Share this post Link to post Share on other sites
cheesy 0 Posted October 19, 2003 my hall sender has gone, have a look at the plug under the distributar it should be tight to the body, if its loose it is probably shorting, mines loose i cable tied mine to make sure it was this as i was getting info all the day, about things to check this made it start fine but once it got hot the engine cut out, i also had slight traces of oil in distributar. You can replace the sender itself but u need to stip down all of the distributar, i've just gone and bought a new one to save time Quote Share this post Link to post Share on other sites
