Jay2 0 Posted January 31, 2007 Just a quick query. Should the Handbrake Handle sit in the middle of the centre trim? Mine seems to have a lean to the drivers side and its pulling the plastic trim towards the seat. I was wondering if over time its possible for it to bend on the mounting brackets through constant use? Starting to have clearance problems with the handbrake sticking on the plastic. Many thanks. Quote Share this post Link to post Share on other sites
Taggart 0 Posted January 31, 2007 Yes, mine has the same issues. The welds are weak at the bottom, I just bent mine back, but it'll snap off in time. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted January 31, 2007 Think they all end up like this. Apparently it's got something to do with the Rado being specifically designed as a LHD car. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 31, 2007 ahm my old G60 had that same issue. I thought it was just the trim that wasnt sat correctly. Quote Share this post Link to post Share on other sites
khurrado 0 Posted January 31, 2007 I actually managed to wrip the handbrake handle out. My mechanic couldnt understand how the bolt on the underside wripped throught the metal. I have since learnt to be gentle when applying the handbrake! Quote Share this post Link to post Share on other sites
Jim 2 Posted January 31, 2007 Strangely I noticed that mine seems to point more towards the driver but thought it was just me.. So yes - I get that too! Quote Share this post Link to post Share on other sites
Slimg60 0 Posted January 31, 2007 I had the same problem as Khurrado, and had to weld some large penny washers. After this it's sat pretty central. Quote Share this post Link to post Share on other sites
fazgti 0 Posted January 31, 2007 I just made this same discovery sunday, thought the surround was loose but the bolt had broken through the weld, just re-drilled a hole and hoping for the best.. Quote Share this post Link to post Share on other sites
