minkeya
Engine conversion (part 2)
Hello agin fellas- Would it be prefferable to fit a Mk3 golf 2.0 16v (abf) engine to my 1.8 16v nugget or should I stick to the 9a.
There seems to be more abf's about and don't they give more break anyway?
Cheers.
I'm not 100% but i did hear that the abf block is taller than the 9a block, and so will struggle to fit into a C due to the slopping bonnet
the abf block is approx 18mm taller so causes downpipe issues and also it uses a different injection system.
This can be converted to run the 1.8 injection though
Use the 9a from passat or corrado as this is a straight swap
