vwdeviant
Early Head light switch...Removal
Ok Am being a bit thick but how do I replace an early headlight switch?
Can I do it without ripping the dash to pieces?
it just prizes out, usual VW spring tabs either side, just be careful as a screwdriver can take chunks out of the dash.
It can be done with fingers, one side then the other.
I think you can pop the blank out and then push the switch out from the back using your fingers.
Yep - as everyone says. Had to change headlight switch on my old G60 and just needed a little force and a large flat headed screwdriver to gently prise it out.
Hm.. in fact I think thats how I did it on mine so..
Unfortunately the blank has the Valet switches for my tempremental Clifford and I'd rather not disturb anything to do with that!
It'll have to be a large flat blade.... and much holding of breath....
