Kick Up The Rs
VDO oil pressure sender
Does anybody know if the 0-5bar oil pressure sender (T11) from VAGarts.co.uk is the dual unit also giving me low oil pressure?
They didn't have any in stock when I called so they couldn't tell me.
At £17 or so quid it looks excellent value considering a 2nd hand one went on Ebay for £34 yesterday!
Cheers.
the only one I can see on their site is the 0-10 bar one, and it does have both connections, one for warning buzzer and the other for a gauge.
only other things are the terminations don't seem to be spade connectors like the ones used on VW's and audis generally and it doesn't say which sender it replaces, so you'll have to check the rating marked on the base of it and replace the appropriate one on the car.
with the VW ones there are 2 types (at least for the 0-5 bar senders) one replacing the low pressure switch (idle pressure) anf the other that replaces the slightly higher value warning switch for low pressure at cruising speed.
Well spotted - the 0 -10 bar in no good for me :(
Looks like I'm gonna have to get ripped off on the bay of fleas for the 0-5 bar unit...
Anybody have one or know of any body who might have one up for grabs before I put a wanted ad out?
keep your eyes peeled for any audi 80 sports or coupes breaking, I've had a couple of senders off those from a scrappy nr me for a fiver a go, sadly I don't have one at the moment though.
