gusto 0 Posted March 4, 2007 Just had a scary sound from the drivers side hub of my winter runner rado. Took off the wheel and the anti roll bar drop link has sheared and the end is rubbing on the driveshaft outer cv joint. Can i just get a new drop link and fit it or is it a case of a new anti roll bar? The drop link is broke at the bottom where it attaches to the hub. Any help appreciated Quote Share this post Link to post Share on other sites
herisites 0 Posted March 4, 2007 You can get just the drop links mate, im replacing mine when i change my wishbones/balljoints/ARB bushes. Quote Share this post Link to post Share on other sites
gusto 0 Posted March 4, 2007 Cool that saves a few bucks! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 4, 2007 get genuine ones also mate, from VAG they are only £12. will take ya about 30mins to do. karl Quote Share this post Link to post Share on other sites
gusto 0 Posted March 4, 2007 How do they detach from the rollbar. I can see it is just a bolt onto the hub Quote Share this post Link to post Share on other sites
Furkz 0 Posted March 5, 2007 yes there not too bad to do, mine fall out all the time specially if i go over humps, due to the drop Quote Share this post Link to post Share on other sites
coolrado 0 Posted March 5, 2007 yes there not too bad to do, mine fall out all the time specially if i go over humps, due to the drop have you tried using the drop links from a caddy van instead? the offset on the top of them is slightly bigger than the corrado ones so it should hold itself on. Quote Share this post Link to post Share on other sites
gusto 0 Posted March 6, 2007 Sorted got the garage to fix my oil leak on my oil cooler too!! Quote Share this post Link to post Share on other sites
herisites 0 Posted March 6, 2007 Do the new drop links make any noticeable difference to the drive of the car? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 6, 2007 demon tweeks modifying catalogue, page 71 spherical bearing drop links in all sorts of sizes. Quote Share this post Link to post Share on other sites
gusto 0 Posted March 6, 2007 Not driven that far yet but will give it a blast in the next couple days and report back Quote Share this post Link to post Share on other sites
