Chris 0 Posted March 10, 2007 so after taking the speedo surround and the blower surround out to fix the last problem i had yesterday, ive managed to cause myself another problem my headlight switch is loose in the dash, i switched them on before driving tonight went to rest it inside the dash again and managed to just catch the metal dash frame on the internals of the switch. there was a spark unsurprisingly not really impressed with the outcome, everything works as it should apart from when i turn the lights on the green speedo / blower / switch lights dont come on. the headlight switch itself light up fine and all the switches still work. its just the green glow lights is there a fuse or relay ive probably blown? im way too tired to work it out right now. the only answer i could come up with was F this right now TIA Quote Share this post Link to post Share on other sites
vr6storm 0 Posted March 10, 2007 its possibly just the rheostat on the h/l switch you've knackered and/or its on its lowest setting Quote Share this post Link to post Share on other sites
Chris 0 Posted March 10, 2007 so its probably just a case of replacing the switch? it was on its highest setting before it all went out just wanted to make sure there werent any fuses/relays i should check first Quote Share this post Link to post Share on other sites
