jgtis 0 Posted October 26, 2003 Washed my vr6 used some colour magic on it, but its still not shinning as i would like :? , should i try t-cut? or whats the best polish 2 make my C really shine. (TWILIGHT VIOLET) Cheers... Quote Share this post Link to post Share on other sites
Jim 2 Posted October 26, 2003 I heard Meguires is excellent stuff... And if you fancy paying out a little, Swissol polish makes your car look stunning! Quote Share this post Link to post Share on other sites
dubbprince 0 Posted October 26, 2003 meguires CLAY is about £12 and is sorta like putty with polish in it...its fantastic stuff! leaves your car looking like glass. :twisted: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 26, 2003 T cut is good stuff but bear in mind what it does (CUT the paint), after applying it you should then wax it to protect the 'new' paintwork Also bear in mind that there is T cut and Metallic T cut Another tip - keep it on the paint only... DO NOT get it on the black plastic trim or window seals! Can also recomend Clay Barring as an alternative - really good finish Quote Share this post Link to post Share on other sites
vr6stormer 0 Posted October 26, 2003 Instead of T-cut try 2 capfuls of Mer after pre-wetting the car and getting the muck off--leave it to dry then shampoo it off and rinse etc. Do this about 3 or 4 times depending on the fade you have then try a good wax after this process--it worked for me anyway. Mer acts as a less abrasive cutter than T-cut in my opinion. Hope this helps. :D Quote Share this post Link to post Share on other sites
john_wintle 0 Posted October 26, 2003 See other threads about this but the best method for te results you require: Don't use T-cut, far too abbrasive, Mer far too dusty (IMO) Wash Clay the car, Use a paint cleaner Wax the car, wash the car frequently with a detergent free shampoo, wax the car monthly Using the above products WILL get the results that I believe that you are after from your paintwork. p.s. Cay bars do not have any polish in them......they are just a special type of clay p.p.s can supply all you need for the above process, email/PM me for more info if required. HTH, John. Quote Share this post Link to post Share on other sites
