jgtis
should i use t-cut on my c.
Washed my vr6 used some colour magic on it, but its still not shinning as i would like :? , should i try t-cut? or whats the best polish 2 make my C really shine.
(TWILIGHT VIOLET) Cheers...
I heard Meguires is excellent stuff...
And if you fancy paying out a little, Swissol polish makes your car look stunning!
meguires CLAY is about £12 and is sorta like putty with polish in it...its fantastic stuff! leaves your car looking like glass. :twisted:
T cut is good stuff but bear in mind what it does (CUT the paint), after applying it you should then wax it to protect the 'new' paintwork
Also bear in mind that there is T cut and Metallic T cut
Another tip - keep it on the paint only... DO NOT get it on the black plastic trim or window seals!
Can also recomend Clay Barring as an alternative - really good finish
Instead of T-cut try 2 capfuls of Mer after pre-wetting the car and getting the muck off--leave it to dry then shampoo it off and rinse etc.
Do this about 3 or 4 times depending on the fade you have then try a good wax after this process--it worked for me anyway.
Mer acts as a less abrasive cutter than T-cut in my opinion.
Hope this helps. :D
See other threads about this but the best method for te results you require:
Don't use T-cut, far too abbrasive, Mer far too dusty (IMO)
Wash
Clay the car,
Use a paint cleaner
Wax the car,
wash the car frequently with a detergent free shampoo,
wax the car monthly
Using the above products WILL get the results that I believe that you are after from your paintwork.
p.s. Cay bars do not have any polish in them......they are just a special type of clay
p.p.s can supply all you need for the above process, email/PM me for more info if required.
HTH,
John.
