doracor
German VR6 - Fuses and Relays arrangement
Newbie here... bought a 1994 Corrado VR6 (German import) a few weeks back.
I ran into a problem with Windows and Central Locking not working suddenly and tracked it down to a Fuse (20Amp) above Relay #15.
But overall I'm confused by the fuses and relay arrangment in my car when compared to some docs I got (which are US/CAN I think).
See attached pic.
The fuses Amps are all over the place. Is there any reason for the Amps to be different from the doc?
Relay #3 is an up side down (109). My doc lists it as (30,32)
But I found this post that seem to confirm that the (109) is correct http://the-corrado.net/.archive/forum/viewtopic.php?t=19131
Relay #15 is an up side down (53). My doc lists it as (78 ).
Is it bad if Relays are up side down?
Any comment will be appriciated.
Anyways... I've corrected tha Amps for all the fuses, and #10 is supposed to be open. Nothing bad so happened so far and found out that #22 for the cigarette lighter is also for the roof light (which my docs didn't indicate).
Anybody knows about these 2 relays #109 and #53 that are upside down. Especially the 109.
Ta
Ta
Hi
Take relay 109 out to take a picture of the pins. Also take a picture of the sides of the relay with a wiring diagram on it.
Put the pictures up and we will try and answer.
