Ryan Davey
arch scuffing
I've lowered my Corrado 40mm all roundand its sitting on 17"s but they wont stop scuffing and my rear drivers wheel arch is starting to chew my tyre, any advice?? I don't really want to put it back to standard as i like the more aggressive appearance. Ta
what rim width, offset and tyre size are you running?
you might be able to sort it with a slightly narrower tyre, but apart from that if you dont want to change the height or the wheels the arches might need to be reshaped a bit.
also what part of the arch is it rubbing on?
