timg60
How do you take off the b piller trim????
As above guys. How do I get the B piller trim off. ( the one with the seatbelt adjustment on it) in one peice....... Cant see how to get it off without breaking something.
Cheers Tim
Pull the coat hook off and undo the screw underneath then pull off the plastic that covers the seatbelt adjuster
(I think!) there is another screw halfway down under a plastic screw cover too!
Its fairly obvious once you get that lot off and not that hard because I managed last summer when the sunroof came out :-)
Cheers
Dan
Have done that and cant get the trim away from the seat belt adjuster. It looks like i could rip it off but then it must be a nightmare to put back together.
Any ideas???
Sorry mate I am desperatly trying to remember how it came off :oops: I have a sneaking feeling that there might have been another screw under the rear side panel, as when I took mine off it came out fairly easly will have a closer look tonight to see if it comes back to me :-)
There seems to be to allen keys holding the mech on for the seat belt adjusters. would I have to undo these?
Tim
there is a screw behind the panel but you will need to carefully bend it down a bit to see it, but dont force it or it mite break, then you can just get a screw driver in to undo
Ok as you can see from the pic you just need to remove the coat hook and screw then the hidden screw halfway down the trim, then pull off the plastic cover on the seatbelt (number 3) and unbolt the top seatbelt anchor :-)
Hope it helps
Dan
Ok that helps loads. I thought I might be able to pull off the knob put after a few pulls thought I might break it.
Now I know it come off will give it a bit more force.....
thank you very much.
Will be able to comple the grey to black transformation now..... :D
WOuld be good if things like that diagram got put on the KB.....
Or maybe I was just being really thick / overcautious
Just get a pdf copy of the bently manual off egay mine only cost a fiver and its saved me ££££££ :-)
just checked on mine now seeing as i have got my interior out and there is a screw just behind the rear panel, which it dont show you in the diagram above
