Critical_Mass
Quick Relay Q?
Just a quick question about the relay numbers that ive got on the fuse board- as i was checking on here for the relay numbers, due to starting problems with my VR. Engine turns but no spark.
Im questioning relay position 3- which i believe is the Digifant control unit
and also position 8 fuel pump relay. After looking on here ive noticed the numbers on the relays differ to other peeps on the forum, who have relay no.30 in position 3 and relay no.80 in positon 12. Is relay 109 correct for position 3 and is relay 67 correct for position 12?
Its a long shot but im trying to get to the bottom of a starting problem, which just suddenly came about without any warning signs.
Thanks all!
Hi
Do you have a dizzy or coil packs
Relay marked 67 is the fuel pump relay in position 12
Remove 67 and clean contacts with a switch cleaner and push back in
