Duecenickletreyg60
windows acting up!
my passenger side window is stuck down as of this morning and my drivers side window will no longer function either. i was in my car when this happened and i dont believe the cables are broke because after the passenger window was down it went back up for a second then it went back down and is now stuck again! does any one have any quick fix im not sure how long before rain will come again!
any help would be nice
take all of the fuses out, clean them with some wirewool and put them back in, I had the same thing a while ago and it worked for me :-)
ok so i cleaned all the fuses and relays and no sucess...however when i un plugged my batt. and then re attatched it the window when back up! as soon as i got back in my c to start it the window dropped again with the turn of the ignition switch. also my drivers side window will no longer roll down....could this problem be coming from the window module i have read about? i'm not too electronic savy so any suggestions will help!
