Trakx
over 1 bar boost
over 1 bar boost?
This is whats happening, don't know if its ok or not.
At full throtle from lows revs everything is ok. Checked at roling road with wideband lambda probe.
I also have a air/fuel ratio gauge in my car, linked to the stock lambda probe (narrowband) and when i go full throtle from low revs the gauge light go green (rich) and stay there.
The problem happens when i'm going half throtle, just enough to be already on boost (like 0.7 bar or so) at more than 3000 rpm and then apply full throtle.
-- The gauge light will bounce up and down (like at idle) for like 2 seconds and then go green.
Don't know if it's ok?
would it have anything with the boost going over 1 bar?
i know the map end at 1 bar but what happens beyond?
does it uses the last values from 1 bar or just shuts down?
