hardyruth 0 Posted May 11, 2007 i recently bought a 92 corrado but the speedometer is not working. i replaced the sensor as part of it was broken off and stuck in the rod. so i then replaced the rod aswell (that goes into the gearbox) but unfortunately it is still not working. i have already checked the connector on the instrument panel and it's fine. i'm really at a loss, i need to get it working...has anybody any suggestions? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 14, 2007 Welcome to the forum! What engine is it?? I assume it's a digital (LCD) clock model so you should be able to put it into test mode and see if the speed signal works, if it does then you can try some new clocks... Maybe also worth checking the gearbox earth as the sensor may need this to work... Quote Share this post Link to post Share on other sites
smee 0 Posted May 15, 2007 Is it just the speedo or are the other clocks playing up? Quote Share this post Link to post Share on other sites
hardyruth 0 Posted May 15, 2007 thanks but i actually got it working, seemed to be the 3 parts from the censor down to the bit in the gear box. Quote Share this post Link to post Share on other sites
nzcorrado 10 Posted June 4, 2013 I am also having this problem my speedo is knocked out ever thing else works( revs gas etc) would it be my sensor faulty or broken? Or possibly one of the 3 wires off it broken? It is a 93 corrado with digital speedo? Any help really appreciated thanks jayden Quote Share this post Link to post Share on other sites
