SIG60
Drinking oil!
Im new to the Corrado scene and my G60 is drinking oil, recently had the stage 4 rebuilt by Jabba and it seems to be still doing it.
Any ideas on what this could be??? - just had the engine rebuilt 1500 miles ago!!
If the engine has just been rebuilt it will use a bit whilst its run in (like a new car does)
I take it you have checked for leaks - gaskets / seals etc, May also be a good idea to look at the heat exchanger as I take it when the engine was rebuilt not all ancillary parts were brand new.
Also who rebuilt it? - may want to take it back for a check up or oil change to a heavier oil?
it shouldnt be using much if all is well....the rings probably didnt seal well,are you using stnthetic oil? if yes thats the prob
