poundhound
High revs between gearchanges
I have a KR valver that doesn't loose revs between gear changes.
It drops if I give it a good rev though.
If its allowed to sit idle-ing it'll settle down too.
I've checked the throttle linkage and it snaps back fine with the cable no sticking at all.
Is it a mucky ISV?
possibly, one of the symptoms can be revs sticking when you de-clutch, often a blip of the throttle will correct it. Not all 1.8 ISV's will recover from this habit even with thorough cleaning, worth a go though..
