kasman21 0 Posted May 28, 2007 hey guys anyone know how to adjust a sunroof!!! mine is dipping to one side! how do i get to the srews to adjust it? cheers Quote Share this post Link to post Share on other sites
M15 VW 0 Posted May 28, 2007 tilt the sunroof up off the switch. The cloth covered panel can then be pushed backwards towards the back of the car. With this pushed back you will see on the left and right hand side two torx head screws at each corner - these are the sunroof adjuster screws. Adjust accordingly. Once you are happy with the adjustment, tilt the sunroof up again off the switch, and then slide the cloth panel forward until it clicks into place.......and hey presto :) Quote Share this post Link to post Share on other sites
kasman21 0 Posted May 31, 2007 i have tried to push the lining back but when i put the sunroof up it raising the lining!!if you know what i mean so i cant push the lining back!! any ideas ?? cheers! Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 31, 2007 tilt it only a little, then grab the tilted bit of the lining and pull it towards the back of the car, it sort of un-clips, slides a little and then can be pushed forwards and drops flat, you can then manually slide the whole lining back into the roof, just don't lose it in there! Quote Share this post Link to post Share on other sites
