valverado 0 Posted June 14, 2007 Hello peeps, Could any1 tell me if a J reg 16v would have the same late spec arches lights , slam panel etc as my K reg 16v, as a barrier hugged my car a little to hard in the wet weather. Thanks :shock: :shock: :shock: :shock: Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted June 14, 2007 Not entirely sure what "arches lights" are, but I don't believe there were any changes between J & K plate Cs. Quote Share this post Link to post Share on other sites
Jim 2 Posted June 14, 2007 J reg valvers should all be 2.0 16v's, in which case you should be fine to mix and match with a K reg valver! As long as its definately a J reg valver.. if its a G60 of the same plate, it could be pre-facelift.. Quote Share this post Link to post Share on other sites
Skimask 0 Posted June 14, 2007 Hello peeps, Could any1 tell me if a J reg 16v would have the same late spec arches lights , slam panel etc as my K reg 16v, as a barrier hugged my car a little to hard in the wet weather. Thanks :shock: :shock: :shock: :shock: Valverado - You'll probably have to look at the car it's possible, to find out if they are the same. VW would look at the VIN plate to ascertain which part is correct. You may have to do the same. The part numbers below are for front wings, left and right - taken from the online ETKA. Probably the earlier valvers and possibly G60's are up to 396* and changed at 397* onwards. The 035000 VIN numbers onwards probably refer to VR6 models. 1 535821021B wing / F >> 50-M-011 396* / see workshop manual left >>50-L-035000 / (1) 535821021D wing / F 50-M-011 397>>* left / (1) 535821022B wing / F >> 50-M-011 396* / see workshop manual right >>50-L-035000 / (1) 535821022D wing / F 50-M-011 397>>* right / 2 311821143 Quote Share this post Link to post Share on other sites
valverado 0 Posted June 15, 2007 Cheers guys im going to look at the car today so all will be revealled :lol: Quote Share this post Link to post Share on other sites
