reubenwilliams
Rims HELP! Fitting Borbet 16x9s... I hope.
Hi Guys,
Im after a set of Borbet A 16x9's (well rears anyway.), very original I know but they look spot on.
I have found a set but the guy does not know the offset.
Were there lots of different offsets available on these rims? Would I need any work done to fit them? (4 stud valver, 92)
ATM i have some Fox racing 17's and i cant put 2 feathers in the back without rubbing. (ok 2 small bricks) :(
Any help you guys can give would be great...
Not sure on different offsets, but you want ET15 offset, which should be stamped on the inside of the rim of the alloy. You will need to roll your rear arches if you haven't already done so too.
mmm, yummy look, OK, its my only car so it cant be off the road during the week to have that done, what size can I go to without any mods, I'm now thinking Borbet T's or BS, could I do a 16 x 7.5 (ET35 for BS and ET 25 for T's) or maybe a keskin KT3 16 x 7.5 et30! and get away with a 40mm drop?
Cheers for your help guys, much appreciated
Its all getting very exciting now!
