DIGGER B 0 Posted August 8, 2007 How easy is it to remove my front bumper ? or is it a pain to get off any advice wld b great thanks. :? Share this post Link to post Share on other sites
Andy665 0 Posted August 8, 2007 Dead easy, couple of screws in each front wheelarch and four bolts underneath, two each side, the outer two of a row of 3, pretty obvious when you look underneath, bumper then just slides off after you've disconnected the lights. I can do it in less than 10 mins now, first time round will take longer but its certainly not difficult Share this post Link to post Share on other sites
CazzaVR 0 Posted August 8, 2007 Basically, it's just held on with 4 (2 on each side) bolts. You can see them once under the car. It's not immediately obvious that they're for the bumper either. Give them a really good soak with WD40 or similar first. Take out the fogs/indicators. Undo the bolts and pull the bumper forward. Make sure you have a blanket on the ground in case you drop the bumper. Easy as. Only prob I had was the bolts took two hours to get undone! Once off the car, give them a good clean and grease before doing them up again, then next time they'll come off nice and easy. Share this post Link to post Share on other sites
CazzaVR 0 Posted August 8, 2007 Beat me to it, Andy! Share this post Link to post Share on other sites
VR6 0 Posted August 8, 2007 Been covered to death. Have a look through the search and there's threads with pictures and everything! :D Share this post Link to post Share on other sites
