Black-16v 0 Posted August 9, 2007 I've done a bit of a search and found a post with instructions from the Bently Manual on how to remove the door glass. Only when i open it its pages of code!! Could anybody else help me with a link to removing and refitting the door glass. Cheers Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 9, 2007 door card off lower door so you can access the bolts at the centre of the bottom of the glass where the reg attaches lower glass 1/2 way down IIRC pop plastic wheels off end of lifting arms and slide out of rail on bottom of door tiltglass forward so back edge lifts out of rear guide and lift up at an angle and out of door should lift out at approx 45 degrees sometimes the bottom rail glued to glass seems to foul on the top plastic end of the centre rail of the regulator but it should come clear witha bit of jiggling Quote Share this post Link to post Share on other sites
