Ru55
new corrado owner - few questions
Car is 1990 spec 1.8 16v
Car is totally standard and it looks like it's flying! so im after some sort of suspension to lower the car, are the struts etc the same as mk2/3 golfs?
Brake pedal is non existant until the end of its throw and then it comes back. thorough inspection and bleeding today but what are the brake upgrade options?
It's running early headlights and they could be better, any suggestions?
any help would be much appreciated.
loving the rado ownership!
headlights are known to be crap on corrado's get your self an uprated loom (ebay or off here somewhere) or make your own. makes a big diference!
Brake wise you can upgrade to the 280mm set up found on a G60 or a VR with 4 stud discs...
Just swap the hub carriers and calipers over?
Yip carriers and calipers from either a VR or a G60 and then get some 280mm 4 stud discs and pads and you in business..
The carriers and calipers pop up on here regularly second hand..
