Ru55
heater matrix
do the corrados suffer the same heater matrix problems as the mk2?
Only mention it because i have the grey dash and fancy replacing it with a black one. Seems worth while swapping the matrix at the same time especially if they have problems. cheers
if you have no recipts for one being done, whilst you have the dash out ill change it mate, as they either weap water or worse case scenereo they explode, they are only 33quid from GSF for a valeo one so whilst the dash is out id do it, as they are a abit of a nightmere to do with the dash in at a later date mate.
simon
Definitely fit a new one for all the reasons mentioned above. I think i'd break down and weep if i fitted a new dash only for the matrix to go a few weeks later!
