corradog60stage4
Experimenting with McCulloch HID lighting system
Since water is a known enemy of many high voltage electrical equipment. I wanted to test my HID lights to make sure they will not cause me any issue even with the slightest amount of moisture.
with over 20K volts passing through the high tension silicone wires and AMP connectors everything must be high quality, waterproof and perfect.
test duration was 8 hours and it made the water hot. not boiling hot but hot
Do you often submerge the front of your car into water?
Least you know your HIDs will be ok now ;)
no i don;t submerge the front of my corrado into water but with snow, sleet, rain, and all the 40 to -40 degree weather we get in canada is pretty close to it. LOL!!!
McCulloch claimed that their kits can be put into water with no issues so I'm just verifying their claim.
