G60MAT 0 Posted August 28, 2007 Just got a 95 VR6 with both original keys. Whats the best and easiest way to add remote locking? Thought most Corrado's like this were total closure - doors/windows/sunroof? Quote Share this post Link to post Share on other sites
Jim 2 Posted August 28, 2007 They do have it from the factory. If you lock the door with the key and keep the key turned to the lock position with the windows / sunroof open, it should close them for you. Most cat1 alarm's should be able to tap into this feature so just a question of getting a good quality, reputable fitter to put a good alarm on your motor :) Quote Share this post Link to post Share on other sites
latestarter2 0 Posted September 9, 2007 prob ive got at the mo is using the remote locking it attempts total closure but the power is cut before evrything has chance to shut..lol Its a clifford one is there a way to have it adjusted so there's enought time to close everything? ta Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 1, 2007 the 'Pulse' time just needs adusting. the alarm will send a pulse of 'X' amount of time to close everything. If this pulse isnt set long enough (seconds) then you may end up with the problem you have. A 45 sec pulse should be long enough to close sunroof, windows and doors. Quote Share this post Link to post Share on other sites
latestarter2 0 Posted November 1, 2007 how do i do that? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 1, 2007 how do i do that? Well unless you how to program the alarm, id get an alarm fitter to do it for you. Give one a call they may be able to advise you. Quote Share this post Link to post Share on other sites
