snattrass 0 Posted September 13, 2007 Press the dash light switch once- side lights come on OK. Press the dash light switch twice- main beam doesn't come on and side lights remain on. Pull the steering column stalk and the main beam comes on - not sure if it's dipped or not. Pull the steering colum stalk again and the main beam goes off and the side lights remain on as before. Any ideas? Some one has suggested the wiper stalk but I think more likely the dash light switch but that's just a guess! I have just bought the car and it apparently has had the uprated loom fitted but that shouldn't cause this problem as I assume it got through it's previous MOT with it on and working. Cheers, SImon. It's a 93 VR6. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 13, 2007 Yeah Switch I reckon, dipped beam should come on at the second stage of the dash switch... Worth checking any relays in the engine bay before you purchase but it's a common fault - switch is about £40 from GPC Quote Share this post Link to post Share on other sites
snattrass 0 Posted September 13, 2007 Thanks mate! What a rip off - think I'll try my chances on a second hand one! Quote Share this post Link to post Share on other sites
madscientist 0 Posted September 17, 2007 Have you tried the fuses first? there should be one for dipped and one main beam each side. Quote Share this post Link to post Share on other sites
