matty golf
plus and eletrics
hi there i got a set of raddo recaros and there is a plug with 7 or 9 wires in it under the seats n e ideas what this is for? if it helps there the grey with diagonal pattern ones plz help a a clueless person
You should have 2 plugs, 1 for the electric motors and another for the heated seats which sounds like the plug your asking about.
Yes there is but if you have the loom for the motors then its a lot more work than that is.
You need the control switch on the dash (2 types, 1 is single dial to control both seats temp known as early type, and later type which has 2 dials to control 1 seat each) the associated wiring and 2 relays i think, possibly stats also, currently looking into it myself.
Can help on the switch front see here
http://www.the-corrado.net/.archive/forum/viewto ... 13&t=60186
Thats the easy bit good luck with the rest, think you will need it.
Use the search for wiring diagrams etc
They did and i have heard rumour that the switch can be taken from there so assume the loom could be as well but whether there is much difference in the length i don't know, so maybe some modification maybe needed.
When you find out more share it on here please :D
Also before you go to the great lengths of finding the parts needed to get warm it may be worth checking the heaters will work with a multi meter for continuity, can somebody advise how this is done on which pins on the plug?
matty golf edit the title so it reads correctly
