Bally
thermostat for KR 16v
seems like im getting hot then cold air.. replaced the heater matrix on the wkend with the thanks of roby d...
anyone got part no's for the thermo??
I'd get one from VAG Bally, the quality of pattern ones varies a fair bit and they're not £££
sounds more like some kind of blockage though, what does the gauge do?
hello Dave, longtime no speak..
Ok mate.. I'll have to pop in to VAG.. wondering if the systems got an airlock.. will have to take a closer look...
yeah, will have to pop round sometime, finally got my new tailgate on (that was more time consuming to swap over than I thought) and the new wing's painted but sitting in my garage till I can be arsed (and probably when the weather's dry and warm!)
Do you have a new VAG matrix?, if so you can ditch the by-pass valve, that might not be helping
Yeh anytime.. give me a shout mate...
Nice one... winter weathers on its way now...
I bought the matrix from good mate at german & swedish in cov... the pipes of the matrix dont have a bypass valve..
Just had the thermostat changed on mine.. one good side effect is that the car no longer takes like 20 minutes to warm up! And heater is a lot more ferocious! :)
has that finally sorted your gauge reading then Jim?
