mistrydog
taking the tailgate off?
the tailgate itself is easy, 4 10mm bolts, 2 on each hinge, it's the loom that's the problem, for that you need to remove the parcel shelf supports, seat belt top fixings, C pillar trim, roof lining rear trim and extract the 4ft or so of loom that goes down inside the C pillar, disconnecting the blocks behind the boot side carpets.
