mistrydog
taking the bonnet off? how??
2 people and a few bolts at the hinges, unclip washer nozzle feed and nozzle heater wiring, unclip from bonnet where needed.
Yeah - easiest way to do it is to remove the bonnet from the hinges, that was it's easy to line back up again as this is put on the car before it's painted so you can clearly see where it meets - suprisingly easy to swap considering the oval holes for adjustment...
I assume your taking a bad one off but if not, make sure you have something soft to put it on and don't leave it stood up on it's 'corners'
