B5VWC
Golf mk3 to Corrado Vr6
Hello
I am new to this forum but just like to say hi and so far i have gained a lot of useful info from this site so far as i am looking for a Corrado VR6.
The reason for the topic is that i have a Golf MK3 GTi 16v which has Koni Coilovers and 17inch Alloys
I noticed on Koni's website that Koni Coilover part 1150-5002-1 for the Golf 3 16v/vr6 is also the same for the Corrado vr6 so would this be a possible swap or would there be a difference
The 17inch Alloys are 5stud same as Corrado VR6(i think) but i guess the offset would be different in this case or not?
If you guys have any ideas or advice let me know.
Thanks.
your KONI's will swap right over.........as my KONI's are also applicable to both MK3 16v GTi and VR6's
and as for offset can't remember off-hand :oops: but its either ET 38 or 43
Hello
Straight swap...as roddy says.
You'll find the front dampers a bit softer on the Corrado VR6 as it has the extra weight to make them a little less harsh...I have the Koni kit on my 16v Mk34 and although they are good, you can tell that they would probably be a little softer on a VR6 engined car.
They'll be fine if they are anywhere between ET43 and 35.
I used to run 7 1/2 x 17 ET35 on my last Golf....currently run 7" x 16 ET 43...both will fit a Corrado well, and due to the larger arches of the Corrado, should provide no rubbing issues.
Thanks for you help guys
Swapped the Koni Coilovers from my Golf to my Corrado and its looking alot better
Here are some pics now with the Golf alloy wheels refurbished
It is a N Plate VR6 metallic black, one owner only with 88000miles
I picked it with 12mths MOT & Tax, Full VW Service History
I will post some more pics of the car later
So far i have fitted a Reiger Grille/Spoiler and Smoked InPro Tail Lights
looks well sweet from the front, did you saying your running coilovers?
I would drop the back abit more...
nice car you don there mate :wink:
Your right, the back does look high
Its Koni Coilovers and they are from my old Golf Mk3 GTi
They were just fitted but not adjusted so i will sort it out
Now i am looking for an exhaust system - magnex or superprint?
anyone fitted magnex, is it quiet and what is the fit like
and what about a air filter, panel or cone on a vr
